Rickles Samba Member
Joined: January 22, 2016 Posts: 213 Location: South Jersey
Posted: Sat Mar 12, 2016 10:39 am Post subject: '66-'67 Headlight "Flashing" (silent horn) |
My parents bought a new '66 Beetle. At the time, the Gov. had VW disable the headlight flashing (silent horn) feature for U.S. bound cars when VW put the dimmer switch on the turn signal stalk. Has anyone found a way to restore the feature? Is there a European turn signal stalk dimmer switch that can be swapped? |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sat Mar 12, 2016 11:24 am Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Sorry, I meant the US Government. The way they mandated a different type of headlights and so forth. I was thinking back to 1966 when the car was new. On European bugs, you could use the dimmer switch to "flash" your high beams when the headlights were off, or have them come on for as long as you held the switch in, besides the regular high beam dimming function. Hence, the term "silent horn". By pressing the switch when the headlights were turned off, you could still activate the high beams. I gues the law was changed later because my 1984 BMW had this function (pull the stalk to flash with headlights off and push it down to activate the high beams when the headlights were on).
Thanks for the link to the diagram. |
grandpa pete Samba Member
Posted: Sat Mar 12, 2016 11:49 am Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Oh! I didn't know that. I thought driving lights were a european thing and folks just flashed their brights to pass. If you're handy with electrics, and could find them, maybe you could install a european relay that kept the dimmer hot/independent of the light switch or, perhaps, you'd need a euro light switch too. Although, I see no euro/us designation on any switches or relays in the classifieds. Maybe someone else can offer a better answer.
Cheers!
Mike _________________ 1964 Sedan 6 volt |
Posted: Sat Mar 12, 2016 12:02 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Your link was very helpful. I went to the Samba wiring diagram archives, and the Non-USA Beetles had a "Combi relay for headlight flashing and dimming" J2 while US models have J2 as "Dimmer relay". More wires on the non-USA relay. |
KTPhil Samba Member
Posted: Sat Mar 12, 2016 12:33 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
The only difference is that on Euro cars, relay terminal 30 goes where it should-- to "always hot" power; on USA models, they jumpered terminal 30 to terminal 56 of the relay, which only has power when the headlights are on.
This is from the Type 3 forum but the relay is wired the same:
http://www.thesamba.com/vw/forum/viewtopic.php?t=341307
See the jumper from 56 to 30 below? Remove the jumper, run a new wire 30, and presto. Just make sure it is a thick enough wire to handle the load of both left and right headlights at once.
Posted: Sat Mar 12, 2016 12:58 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
That looks pretty easy, thanks. |
j.goodspeed Samba Member
Posted: Mon Mar 14, 2016 2:48 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Thanks; all of the information that everyone has offered is very helpful. I'm buying a nice '67, but I don't have it yet. This will be something to play around with when i get it. I'm guessing the newer bugs, '72-ish, had a turn signal switch that you could pull toward you to flash and push down to turn on the high beams. |
Posted: Mon Mar 14, 2016 3:00 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
You can do it with a 67. You just need the powered Hi/Low relay mentioned in the other post. _________________ Jeremy Goodspeed
www.goodspeedmotoring.com
www.goodspeedmotoring.net |
Posted: Mon Mar 14, 2016 3:07 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
I'll do that; thanks again. |
KTPhil Samba Member
Posted: Mon Mar 14, 2016 5:04 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Rickles wrote: |
I don't think they ever worked that way. You pulled it toward you to either flash (if headlights were off) or to alternate between high and low beams.
The stalk just made momentary contact which flipped an oscillating relay to either high or low position with each press. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Mon Mar 14, 2016 5:18 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Do you still have the switch on the turn signal arm?
http://www.thesamba.com/vw/classifieds/detail.php?id=1799658
_________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Mon Mar 14, 2016 5:39 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
KTPhil wrote: |
Rickles wrote: |
Thanks, I was just guessing based on a BMW I once owned. |
Posted: Mon Mar 14, 2016 5:40 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
Yes, switch is fine. Thanks. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Mar 14, 2016 8:18 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
I have learned something new finally here- "silent horn"!
I didn't realize I've been using one for years- favoring it as a friendly(er) reminder on my M/C. My Volvo may as well be stuck in silent horn mode all the time- my morning commute involve 1000s of idiots. I'm always flashing to get the doofi out of the fast lane driving at the posted limit. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Mar 14, 2016 8:44 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
hitest wrote: |
I didn't realize I've been using one for years- favoring it as a friendly(er) reminder on my M/C. My Volvo may as well be stuck in silent horn mode all the time- my morning commute involve 1000s of idiots. I'm always flashing to get the doofi out of the fast lane driving at the posted limit. |
I liked that too, learning and stuff. I have heard this referred to as autobahning, but couldn't find any mention of that term on the cave walls (google). Silent horn is nice, now to build a bigger motor to necessitate the need for a silent horn.
Really glad you found what you were looking for Rickles.
Cheers!
Posted: Tue Mar 15, 2016 7:12 am Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
I certainly appreciate everyone's help, thanks. |
Posted: Sun May 29, 2016 1:40 pm Post subject: Re: '66-'67 Headlight "Flashing" (silent horn) |
I finally replaced the flasher relay this afternoon. Very easy; so cool to have my "silent horn" working. Thanks for all the help and to everyone that replied. |
