The Stupid Question Thread
Page: Previous  1, 2, 3 ... 27, 28, 29 ... 126, 127, 128  Next
clay ford
clay ford is offline
PostPosted: Fri May 06, 2016 3:52 am    Post subject: Re: The Stupid Question Thread Reply with quote
Stephen. wrote:
Can a 1969 bug with a healthy 1600 engine tow another bug? I am looking to pick up a project bug/baja and was wondering if I had to could I tow it with my bug?
I dont think it would be much of a problem as long as you dont push it too hard.
artistic_gore
artistic_gore is offline
PostPosted: Sat May 07, 2016 11:34 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I am having trouble getting the tin out from under the pulley to pull the motor, it's hanging on the pre-heat tubes, does the intake need to be removed to get the tin out?
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Sun May 08, 2016 8:08 am    Post subject: Re: The Stupid Question Thread Reply with quote
If you're referring to the tin behind the lower pulley, you need to remove the pulley and there are two small screws holding the tin in place.
The Samba member since 2004.
kirk1015
kirk1015 is offline
PostPosted: Sun May 08, 2016 9:31 am    Post subject: Re: The Stupid Question Thread Reply with quote
I have a stupid question. Very Happy MAYBE REALLY STUPID
I changed out the fuel lines in my Super Beetle. When I took the filler neck
hose off gas flowed out and down the trunk and under the car. Now my garage and the car reek of gas, along with a stain on the floor under the passenger front wheel. Embarassed
Of course when I put the new hose on, no more gas coming out.
Here comes the stupid question. Should I be afraid to start the car? Maybe let it roll out and start the car in the driveway?
Is there an award for stupid question of the year? If so, maybe I should be nominated. I just say what other people might be thinking "is this guy and idiot" My answer would be "sometimes, sometimes I am"
I should be more careful I know.
Jim Douglas....I am Not.
Samba Purist
wcfvw69 is offline
PostPosted: Sun May 08, 2016 9:47 am    Post subject: Re: The Stupid Question Thread Reply with quote
I'd just keep the garage door open for a few hours to let it air out. The gas will evaporate quickly..
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun May 08, 2016 10:55 am    Post subject: Re: The Stupid Question Thread Reply with quote
X2 on what Bill said. Also roll the car out into the driveway and let it air out a little as well.
FWIW if there was an award for a Stupid Question, you'd at least make a podium finish Shocked
Have a great day. Call your mom and wish her a Happy Mothers day!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
TheStanfordWagen
TheStanfordWagen is offline
PostPosted: Thu May 12, 2016 8:01 am    Post subject: Re: The Stupid Question Thread Reply with quote
Looking at the cylinder heads, which valves are exhaust and intake? And how does the carb preheater hose tin attach to the muffler?
1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
Solex 30 PICT-3
Fahrgest.-Nr. 118096544
PatsGhia
PatsGhia is offline
PostPosted: Thu May 12, 2016 7:58 pm    Post subject: Re: The Stupid Question Thread Reply with quote
The valves toward the outsides of the heads are exhaust, the inners are intakes. If you are talking about the "stovepipe" then 1 of the straps goes under the lower exhaust nut at the head, and 1 connects to the rear tin.
Lingwendil
Lingwendil is offline
PostPosted: Sat May 14, 2016 10:27 pm    Post subject: Re: The Stupid Question Thread Reply with quote
you are probably hung up on these screws
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
clay ford
PostPosted: Sun May 15, 2016 5:32 am    Post subject: Re: The Stupid Question Thread Reply with quote
not necessarily a stupid question but i dont think it needs its own thread, im trying to order new tie rod ends, what year did vw swap over to larger tie rod ends? i swapped my 68 bug over to disk spindles and the original tie rod ends were too small.
TheStanfordWagen
PostPosted: Sun May 15, 2016 9:37 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks!
113-905-205K
Solex 30 PICT-3
mark tucker
mark tucker is offline
PostPosted: Wed May 25, 2016 7:37 pm    Post subject: Re: The Stupid Question Thread Reply with quote
so...what are the 2 holes in my pully for that alien with those 2 screws????? Shocked
Phil Plummer
Phil Plummer is offline
PostPosted: Thu May 26, 2016 7:53 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Rolling Eyes
hi can abyone tell how to take a fuel door of a standard 74 beetle ? it looks like a one way assembly.
and does winshield have to come out to change defrost vents?
itskyle
itskyle is offline
PostPosted: Sat May 28, 2016 10:59 pm    Post subject: Re: The Stupid Question Thread Reply with quote
OK, I've got a couple...
Best sources for wiring harness (complete) for 69-72 standard autostick bug
Best source for passenger side floor pan?
And, a bonus
69-72 autostick bug. new battery. known good generator. occasionally needs jumped to start?
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.)
ElkoT1
ElkoT1 is offline
PostPosted: Wed Jun 01, 2016 5:01 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I need some info help I'm using some VW parts in a non VW build. Are VW bug torsion bars a 40 spline count and is it the same on both ends? Also is the 26 9/16 as long as I can find or is there longer ones on different models?
mark tucker
PostPosted: Mon Jun 13, 2016 11:07 am    Post subject: Re: The Stupid Question Thread Reply with quote
why did I plant that pear tree there Shocked dang it's starten to get a tad bit warm today.
tonysantacruz
tonysantacruz is offline
PostPosted: Sun Jun 19, 2016 9:44 am    Post subject: Re: The Stupid Question Thread Reply with quote
The steering wheel of my Mexican 1994 bug is not the one I want. I wonder if you can fit this one this one from the 70's or this one classic 80's or my favorite if i can get it. Can it be done or there are a bunch of extra pieces needed?
mark tucker
PostPosted: Tue Jun 21, 2016 6:52 pm    Post subject: Re: The Stupid Question Thread Reply with quote
why dont I go surfing more offten? the beach was awesome today!!!!!almost alll day!!!!sun screen is my friend. and the hotties were oh so hot too. Shocked Rolling Eyes Cool
bellabug
bellabug is offline
PostPosted: Wed Jun 22, 2016 10:57 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Does the main loom go through the hole near the rear footwell to the engine?
If it has been cut near the heater channel would you expect the other half of the loom to be inside the rear panel towards the engine?
(Pic for clarification)
Puebla Bug
Puebla Bug is offline
PostPosted: Tue Jul 05, 2016 12:24 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hey everyone, I'm new to beetles and I bought a 74 with a 1915cc w/44 IDF carb. I've heard that the more you mod it the more maintenance that they will require. Would it be better to just buy a 1600 with some bolt on performance parts to reduce the amount of work it needs?
My main goal with this car is a daily driver with moderate offroad use, i.e take it on the beach and traverse dirt roads as I go to ranches every now and then.
Thanks!
Page 28 of 128
