Sofia74 Samba Member
Posted: Sat May 28, 2016 4:21 pm Post subject: Protecting cleaned and blasted metal |
I am looking for a way to protect metal - both the body and random pieces - after I either media blast the small parts or mechanically clean the larger parts.
Have to keep in mind this restoration will likely take a couple years so parts will sit in this coating for a while. And being WV, the parts will be stored in a relatively humid environment. I have a dehumidifier running but its an uphill battle…
I am leaning towards a metal prep (looking at one from Eastwood) and then a self-etching primer. I have read many opinions on a number of sites - epoxy versus self-etching. I am willing to regrind the coating prior to welding or body filler if that is important.
As always open to any opinions and recommendations.
Thanks,
Matt |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sat May 28, 2016 5:52 pm Post subject: Re: Protecting cleaned and blasted metal |
I can tell you that etching primer is best for bare metal finish. I don't think there is anything else that will last months let alone years in a humidity. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sun May 29, 2016 2:02 am Post subject: Re: Protecting cleaned and blasted metal |
in Australia we have a product called Bonderite M-ZN 253 (previously known as Kephos or Paintgrip 253). It is made by Henkel and is a solvent that you spray onto clean bare metal and it produces a thin coating that prevents rusting and you can paint over it.
I apply it using a household trigger spray after using another Henkel product called Bonderite C IC 624 (previously known as Deoxidine 624) which you apply using a scotchbrite to remove surface rust.
These exact product names don't seem to be sold in the US but Henkel do sell Bonderite solvents in the US so they should be able to tell you the US equivalent.
These are excellent products and are perfect for what you want it for. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Sun May 29, 2016 3:43 am Post subject: Re: Protecting cleaned and blasted metal |
If it is indoors then the metal prep will be enough. But having used both I vastly prefer Ospho which is sold for $24 a gallon in my local ACE hardware. It is stronger and doesn't leave a brown color. turns bare steel a dull gray and light surface rust black. If you are really worried then a coat of epoxy primer will make it so you won't have a problem even 10 years later. Acid etch primer is not used too much anymore. mostly on just small areas. It will work, but I don't think it is your best solution. |
Posted: Mon May 30, 2016 7:50 am Post subject: Re: Protecting cleaned and blasted metal |
Thanks for the replies. The car will remain indoors so I'll start with the metal prep and see how that goes.
Since this will likely go slowly, the metal prep could give me opportunity to get a lot cleaned up and then epoxy prime more at once - maybe the whole body... |
jason Samba Member
Posted: Tue May 31, 2016 7:42 pm Post subject: Re: Protecting cleaned and blasted metal |
If you're gonna use a solvent, use etching primer. Epoxy doesnt like anything on the metal. If you do make sure to surgically clean it. A bit of heat will help, it releases the solvents. Best would be clean small area then epoxy. Its waterproof and you can put the filler on top. |
