Rough turn then no electricity
psc2612
psc2612 is offline
PostPosted: Mon May 23, 2016 8:33 pm    Post subject: Rough turn then no electricity Reply with quote
My 66 beetle experiences rough engine turns and then when it won't start the next time I turn the key nothing happens. If I pull the black cable to the starter I have electricity again. I've been looking everywhere to see if this happened to anyone else but I can't find anything. Are these symptoms of a bad starter?
grandpa pete
grandpa pete is offline
PostPosted: Mon May 23, 2016 8:51 pm    Post subject: Re: Rough turn then no electricity Reply with quote
It sounds like a bad ground strap ;check the tranny ground strap AND the battery ground .
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
mukluk
mukluk is offline
PostPosted: Fri May 27, 2016 3:12 pm    Post subject: Re: Rough turn then no electricity Reply with quote
Bad starter? Not so much. More like bad cables or at least loose or corroded cable connections.
