onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Wed May 11, 2016 6:23 am Post subject: Re: LED Headlights |
Drewmon wrote: |
Please do, I've been eyeing those for a while too. Let us know how you make out. |
In the meantime, you might check out these posts:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8076432#8076432 _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
bugdust Samba Member
Joined: September 02, 2002 Posts: 606 Location: Austin, AR
Posted: Wed May 11, 2016 8:27 pm Post subject: Re: LED Headlights |
I use TrucklLites in my Jeep. I wonder how they would do in a vintage VW. They aren't a good look for most but in a buggy, baja, volksrod etc they might look ok. They are awesome lights. |
Posted: Wed May 25, 2016 4:41 pm Post subject: Re: LED Headlights Update |
17 days and counting since they said they were sending them back to me. Turns out USPS lost the shipment and they're sending me a new set. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
jarrod78 Samba Member
Joined: November 12, 2015 Posts: 2 Location: San Marcos, California
Posted: Fri May 27, 2016 11:59 am Post subject: Re: LED Headlights |
I've had the vintage LED bulbs in for 4 months now and working great. running alternator myself. |
vintagecarleds Samba Member
Joined: April 28, 2015 Posts: 178 Location: Houston, TX
Posted: Tue May 31, 2016 4:59 am Post subject: Re: LED Headlights |
jarrod78 wrote: |
Jarrod, if you have a photo of your bug with the headlights in we would love to put it on our website if you have time! _________________ www.vintagecarleds.com
[email protected]
713-853-9644 |
Posted: Sat Jun 04, 2016 1:05 pm Post subject: Re: LED Headlights Update |
First shipment got lost in the mail so they were good enough to send another set. They arrived a couple of days ago.
I just put them in and tested them. With the car warmed up and idling I was getting 13.9 V at each lamp, high and low. Holy cow! I think the cleaning and the new foot switch and the new light switch really did the trick.
Time will tell, but I think they'll be fine now. I love these lamps!
These guys are the best. I feel so bad since it was my voltage drop that caused all the trouble.
I also installed some great LED parking lamps from http://auto-hub.com/ba15s-led-98-bulb/ _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
EVfun Samba Member
Posted: Sat Jun 04, 2016 1:27 pm Post subject: Re: LED Headlights |
Now if someone would come up with LED retrofit headlights for 6 volt cars. I'm sure my 180 watt generator doesn't appreciate having 120 watts used by just the H4 high beams (55w/60w bulbs.) _________________
Wildthings wrote: |
Posted: Thu Jun 09, 2016 6:28 am Post subject: Re: LED Headlights |
EVfun wrote: |
Now if someone would come up with LED retrofit headlights for 6 volt cars. I'm sure my 180 watt generator doesn't appreciate having 120 watts used by just the H4 high beams (55w/60w bulbs.) |
We are currently working on 6 volt kits, and we are in the road testing phase of them. _________________ www.vintagecarleds.com
[email protected]
713-853-9644 |
notsnarb Samba Member
Posted: Thu Jun 09, 2016 7:06 am Post subject: Re: LED Headlights |
EVfun wrote: |
They are already on Samba, expensive but they exist:
http://www.thesamba.com/vw/classifieds/detail.php?id=1775896 |
Posted: Thu Jun 09, 2016 7:07 am Post subject: Re: LED Headlights |
branston wrote: |
EVfun wrote: |
That's why we are developing a more affordable solution.
Also, the only thing that bugs me about that ad
"they produce no heat, operate at room temperature"
Which isn't possible for High Output LEDs, notice they have a heat sink, and cooling fan.
Also the bulb is exactly the same as ours in our VC2500 kit. (our older kits) _________________ www.vintagecarleds.com
[email protected]
713-853-9644 |
Posted: Tue Dec 06, 2016 3:59 pm Post subject: Re: LED Headlights |
I was still having some issues with the LED's, so vintagecarleds.com sent me a set of their new VC3500 lamps, better LED's, no fans. These are fantastic! These guys went out of their way to make me happy. Great company.
VC3500
https://vintagecarleds.com/shop/7-inch/vc3500-classic-kit/ _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
