BluzBug Samba Member
Joined: February 23, 2010 Posts: 237 Location: Spring Arbor, Michigan
Posted: Mon Feb 23, 2015 4:29 pm Post subject: 68 Type 3 Operating Rod Guide Bushing .. Source |
Located on Swing Axle. Part Number 361 501 753 ... I'm aware one seller in Classifieds (Germany) .. but, i can't find others, or i overlooked @ISP i didn't see the Bushings i need. Thanks, BluzBug
http://www.thesamba.com/vw/classifieds/detail.php?id=1476549 |
kirschwagen Samba Member
Joined: April 11, 2005 Posts: 113 Location: bristol, rhode island
Posted: Fri May 27, 2016 9:39 am Post subject: Re: 68 Type 3 Operating Rod Guide Bushing .. Source |
I too am searching for 361 501 753. Came across your post.
Wish to add to it and reopen the topic too.
Have found several of the usual vendors do sell an entire
z-bar rebuild kit, but it has many extra tubes and bushes
which a T3 does not need.
Which poses the question...are these kits T1 based?
Further, could it be that 113 501 753 (z-bar guide) simply replaces 361 501 753.
and 361 501 737 (z-bar bumper) consequently can be swapped to 113 501 737?
If anyone has the answer, or has tried this substitution already, please let us know.
My '68 swing-axle square could use a fresh set of these bushes as well.
thanks! |
tweakhx Samba Member
Joined: April 11, 2012 Posts: 156 Location: South Dakota
Posted: Tue Jun 07, 2016 8:20 am Post subject: Re: 68 Type 3 Operating Rod Guide Bushing .. Source |
I'm also looking for a source for these. This is a picture of mine, right rear. It can come off if you pull it hard enough. Bushing appears to be black. Sorry for the lack of a close up.
Perhaps it's something one would have to improvise?
Thanks,
_________________ 1968 Diamond Blue FI Fastback
1969 Diamond Blue FI Fastback Auto
1971 Pastel White Westfalia
2007 GTI
2012 Beetle 2.5L
endle wrote: |
Ever since I bought a vw I have not been able to keep my fingernails clean.
stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
Posted: Tue Jun 07, 2016 10:45 am Post subject: Re: 68 Type 3 Operating Rod Guide Bushing .. Source |
Mine will just slide off, So i removed the bolt and installed a large washer to hold it from backing off, problem solved for now until the rubber bushing just flat falls apart. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Tue Jun 07, 2016 10:53 am Post subject: Re: 68 Type 3 Operating Rod Guide Bushing .. Source |
stonecoldcars wrote: |
Mine will just slide off, So i removed the bolt and installed a large washer to hold it from backing off, problem solved for now until the rubber bushing just flat falls apart. |
Very good idea! Thanks! _________________ 1968 Diamond Blue FI Fastback
2007 GTI
2012 Beetle 2.5L
endle wrote: |
