Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Wed May 25, 2016 10:53 pm Post subject: Jetting for a 44 IDF Center Mount on a 1776 |
I have a sand rail that I recently purchased with a center mount 44 IDF with the following setup. It eats (carbon fouls) spark plugs like crazy.
175 Air correction
F11 Emulsion tube
155 main
30 venturi
55 Idle
Can I keep the F11's or do I need f7's?
Air correction 160?
135 mains?
I have never ran one of these center mount carbs and I have no idea where to start. _________________ 1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver |
drumbum68 Samba Member
Posted: Thu May 26, 2016 7:13 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
Exhaust and manifold mods. A wide band for jetting.
I would start with a 40idf and a proper mani. |
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Thu May 26, 2016 7:59 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
The intake manifold is probably too big so there is no velocity (regardless of carb) and the fuel is puddling up and dripping into the cylinder and fouling plugs.
First things first. we need a picture of the manifold that is being used. also can you measure the tube on the intake that runs to the end castings.
I assume that since it is a rail, there is no preheat to the intake so that isn't helping but it is not the end of the world if we can get the intake to the right size.
and yes, either way a 36 or 40 carb with a 28 vent will be better suited to the engine size. _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
raymon covey Samba Member
Posted: Thu May 26, 2016 8:05 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
I went to F-7 and it was completely different. You could also use F-2 |
Posted: Thu May 26, 2016 8:07 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
What sized engine and what jetting? _________________ 1966 Euro
1600DP
Dual 34mm ICT's
Posted: Thu May 26, 2016 8:27 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
start with
F7
55 idle
125 main
180 air
Nevada Notch wrote: |
175 Air correction
F11 Emulsion tube
155 main
30 venturi
55 Idle
Air correction 160?
135 mains?
I have never ran one of these center mount carbs and I have no idea where to start. |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu May 26, 2016 8:31 am Post subject: Re: Jetting for a 44 IDF Center Mount on a 1776 |
Thank you John!
That's where I'll start. _________________ 1966 Euro
1600DP
Dual 34mm ICT's
