c.j. Samba Member
Posted: Mon May 23, 2016 2:58 pm Post subject: Gas tank expansion |
Is this hose enough to vent this gas tank for expansion?
[/img]
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon May 23, 2016 3:41 pm Post subject: Re: Gas tank expansion |
Yes _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Mon May 23, 2016 4:29 pm Post subject: Re: Gas tank expansion |
yes but it's not for expansion. It allows air in to replace the fuel used so it doesn't get a vacuum on it and starve the pump. Much like a motorcycles vented cap etc. new cars don't have this because the pump pressurizes the tank and pushes it to the engine.
It would take a lot of pressure to expand the metal tank in ghias. And then you might want to stand well back. _________________ 63 ghia coupe |
c.j. Samba Member
Posted: Tue May 24, 2016 4:25 pm Post subject: Re: Gas tank expansion |
Cool,I just wanted to make sure it was enough to vent the tank since I have a 68 and plugged the larger hose near the filler neck that ran out the passenger side fender.
Posted: Thu May 26, 2016 5:05 am Post subject: Re: Gas tank expansion |
You have blocked off the fill breather line which is different to the tank vent line - with this blocked off you may have problems with the pump cutting out when you are filling _________________ 1962 Karmann Ghia
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu May 26, 2016 7:58 am Post subject: Re: Gas tank expansion |
I am guessing what you have is a fuel tank that is not correct for your year car but as close as it gets for a replacement part.
On my 71 there is a tube through the fender that connects to the line you blocked off. Its not on your car. The other end of the tube connects to the fill tube in the fenderwell. Its to prevent overflow. If you have a vented cap or a breather line elsewhere you are probably Ok. _________________ Ghia Owner Emeritus |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Thu May 26, 2016 2:25 pm Post subject: Re: Gas tank expansion |
NOVA Airhead wrote: |
On my 71 there is a tube through the fender that connects to the line you blocked off. Its not on your car. The other end of the tube connects to the fill tube in the fenderwell. Its to prevent overflow. If you have a vented cap or a breather line elsewhere you are probably Ok. |
I was looking at that same picture and was wondering what happened to the missing tube. My 71 is also just as you described. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
c.j. Samba Member
Posted: Thu May 26, 2016 6:19 pm Post subject: Re: Gas tank expansion |
Yes my 68 had a one year only gas tank before being replaced with a newer tank.I used to have that larger hose hooked up to a metal tube that comes out on the inside the passenger front fender behind the wheel ''68 only'' but lots of gas smell when making left turns. |
