Mark33563 Samba Member
Joined: November 13, 2005 Posts: 1667 Location: Tampa Bay. FL
Posted: Mon May 23, 2016 6:12 pm Post subject: Type 3 inner rear fender question |
With her help, we started putting my daughter's Squareback together last Saturday. She is an excited 14 1/2 year old. As with all projects, some questions have arisen...
What seals are people using between the outer and inner fender (air intake, fender well, etc.)?
Also, anyone know where some front turn signal seals for a 73 can be had? seems to be a non-repoped part.
Thanks.
--Mark _________________ -—--------—-------
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon May 23, 2016 6:47 pm Post subject: Re: Type 3 inner rear fender question |
ISPwest has a great diagram for part numbers, and carries most of the parts; see the lower right corner here:
http://www.vwispwest.com/pg105/
52, 54, 68
Late front turn signal rubbers are very hard to find. Looks like they got some Lefties in stock. L and R are not interchangeable.
http://www.vwispwest.com/311953153C.html |
Posted: Mon May 23, 2016 7:01 pm Post subject: Re: Type 3 inner rear fender question |
Thanks for the ISP West info, seem to have forgot to search their site.
Any idea as to whether or not 68-69 turn signals would fit? Drilling new holes would not be an issue. Curvature of the fender and large hole in fender are.
might have to just get the fenders welded up and go with an earlier year turn signal.... _________________ -—--------—-------
KTPhil Samba Member
Posted: Mon May 23, 2016 7:12 pm Post subject: Re: Type 3 inner rear fender question |
Wraparounds will not fit. Bullets can be made to fit.
Check the classifieds for used rubber seals... they do show up and can be reconstructed to work, even if damaged. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue May 24, 2016 12:50 pm Post subject: Re: Type 3 inner rear fender question |
the body work on the car is 100% down to the paint. Fender swap may happen in the future. right now i just need to get his thing together.
Looks like those adapters area a bolt in type of thing. Granted, welding would be much better. Might have to go that route for short term 'satisfaction' and keep an eye out for front fenders.....
I just need to buy a parts car... _________________ -—--------—-------
Dodgy Samba Member
Joined: January 30, 2006 Posts: 517 Location: Leicester, UK
BluzBug Samba Member
Joined: February 23, 2010 Posts: 237 Location: Spring Arbor, Michigan
Posted: Thu Mar 23, 2017 10:28 am Post subject: Re: Type 3 inner rear fender question |
Does anyone know where the above parts are available in the U.S. ... other than ISP West? Much prefer to buy them "Off the Roll" |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Thu Mar 23, 2017 11:51 am Post subject: Re: Type 3 inner rear fender question |
BluzBug wrote: |
That sponge "cord" extrusion is available from mcmaster carr. You are looking for EPDM foam cord. It comes in 1/8" to 1/2" diaketer in 100 foot lengths.
Cheap for what you get but 100 foot is. $51.80.
might want to split the cost with a few others . You can also by rubber cord products from Auveco.....check their on line catalog. You can also get the self adhesive foam blocks at Auveco....or buy sheet EPDM foam from McMaster-Carr and use 3M 486 adhesive or similar. Rwy |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Mar 23, 2017 12:28 pm Post subject: Re: Type 3 inner rear fender question |
raygreenwood wrote: |
BluzBug wrote: |
McMaster also offers a "bulb" style seal that can be used for the wheel well lip to fender. I don't have the part number available on this computer, but I know they sell it (bought some in the past). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
tdrrally Samba Member
Joined: January 05, 2011 Posts: 181 Location: charleston,wv.
Posted: Fri Mar 24, 2017 6:23 am Post subject: Re: Type 3 inner rear fender question |
i would be interested in going in on that |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Fri Oct 02, 2020 3:27 pm Post subject: Re: Type 3 inner rear fender question |
No.
That is polyurethane foam. Wrong material and wrong production quality. That is essentially the same material as lengths of split water pipe insulation and usually has an open cell structure and is not ideal for full outdoor use.
You are looking for foam made from EPDM rubber....no other material.
EPDM is what the windshield rubber on your car is made of and what brake seals are made of. It is very UV, water and ozone resistance...but fair warning....it is not hydrocarbon resistant...so do not get solvents or oils on it. Ray |
