Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Wed May 25, 2016 4:52 pm Post subject: Oil relief plug washers?? |
Do these not come in the complete seal/washer/gasket rebuild kit?
or are there not intended to be any washers beneath the plugs?
thanks in advance,
Rev. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Wed May 25, 2016 4:55 pm Post subject: Re: Oil relief plug washers?? |
yes, they come in the kit.
If they aren't squashed, you can put a light coat of ptfe sealer on there and use them over too. |
Posted: Wed May 25, 2016 5:00 pm Post subject: Re: Oil relief plug washers?? |
thanks, Glen.
I found one in the kit, but it's also the same size as the oil drain plug -
but there was only 1??
did find another in the drawer of leftover pieces parts.
I am hoping to keep the other case together and intact to I can put the original 2007 back together again. without too much robbing Peter to build Paul's motor.
Got it squared. Thanks again.
76 914 with 2260
79 VW Iltis
69 Bwajaja
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed May 25, 2016 6:42 pm Post subject: Re: Oil relief plug washers?? |
the last Elring kit I bought didn't have any, had to order a bunch online from a hydraulic shop. _________________ modok wrote:
esde Samba Member
Posted: Wed May 25, 2016 6:46 pm Post subject: Re: Oil relief plug washers?? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
