M Chrispyn Samba Member
Posted: Wed May 25, 2016 9:59 am Post subject: Axle Seals |
I have replaced the outboard axle seals on a 67 Beetle 3 times, they keep leaking even when the car hasn't moved. Have been very careful to not damage the o rings or the gaskets. Have 90 weight gear oil in it up to the fill hole.
Any ideas? |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
Posted: Wed May 25, 2016 10:07 am Post subject: Re: Axle Seals |
Where is it leaking from? If it is leaking from behind the backing plate, put a gasket between the carrier and backing plate. Make sure all parts are in order
and tighten axle nut to the proper setting. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Wed May 25, 2016 2:54 pm Post subject: Re: Axle Seals |
I use black RTV and never have leaks. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed May 25, 2016 6:48 pm Post subject: Re: Axle Seals |
Thanks for the replies. It is leaking from around the outer axle seal. Up on further checking I think I had it too full and the car is off the ground and the axles are hanging lower than the rear end housing which I think are the two main causes, I'll correct those two and see what happens then. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Wed May 25, 2016 8:16 pm Post subject: Re: Axle Seals |
I have had trouble with the axles leaking too.
I found the seals are easy to damage when installing the caps. Be very careful slipping them onto the axle spline.
Also make sure you don't buy the cheap seal kits.
Be careful when pounding the seal into the cap and lube the inside before installing onto the axle making sure you don't damage anything and also make sure everything is in the correct order.
It is easiest when the axle is level so that gear lube is not leaking out getting the gasket all wet with oil. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
