67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9754 Location: Oregon
Posted: Wed May 25, 2016 6:33 pm Post subject: Type 3 dist on a type 1 engine??? |
I'm curious if I can use a 311 905 205G dist on my dual carbed 1679 type 1 engine. I have a huge timing flat spot at mid throttle that I can feel while driving and see it with a timing light. Current dist is a 034 SDVA with pertonics. Timed at 7.5* btdc. Carbs synced and recently cleaned. Valves adjusted a few weeks ago.
I recently tried an 009 vac advance (stock 67) dist from my reliable 1500 engine. It ran ok and was quite drive-able. It just didn't have any umph on acceleration. So I reinstalled the 034 and was happy with the acceleration. But unhappy with the mid throttle flat spot in the timing.
If I can't use the 205G. What dist would play well with my
CB Perf. 32/34 psdit carbs?
Thought that I would ask this as there is a VW event coming up where there should be a few vendors selling serviceable distributors in the swap area.
Thanks in advance for any help / advice that you send my way. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
