Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Wed May 18, 2016 8:28 pm Post subject: Re: The Stupid Question Thread |
Where can I get quality clips for the sliding door cable of a 78 Westy? I don't know the part number. The last time I ordered something like this they didn't fit. I think someone more experienced and knowledgeable could help make sure I order the correct part the first time. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1765 Location: Newmarket, ON
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Tue May 24, 2016 3:41 pm Post subject: Re: The Stupid Question Thread |
Globespotter wrote: |
Anyone considered putting Dura liner or Herculiner on the front floor instead of the rubber mat?
It seems to me that any mat can retain moisture underneath. |
That's a tricky one. My bus came LOADED with Reflctix, and the front floors were starting to bubble up under the carpet within the first two years of the fresh paint job. I don't recommend it. Reflectix and carpet replaced with rubber mat, rust catalyzed, and top coated, and it has not gotten any worse in four years since.
Make sure your car is well-sealed, and I mean REALLY well-sealed. Then keep the paint waxed under there. That, with a rubber mat, is about as much protection as you'll need.
www.airschooled.com |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu May 26, 2016 9:15 pm Post subject: Re: The Stupid Question Thread |
^^ I had the same experience, but fortunately caught it early. Floors see more water than other areas, so unless you've stripped them and are confident there are no tiny rust spots, I'd be wary to put something down. That being said, lots of people do it.
The rubber mats don't sit flat on the floor, they have ribs on the back so there isn't much contact with the metal. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701
Posted: Thu May 26, 2016 9:20 pm Post subject: Re: The Stupid Question Thread |
I have a gap on either side of where my pop-top meets the luggage rack, but it sits flush in the middle. It's a late bay, so that acts as a wind scoop on the highway. The back sits a bit low, but the bar that holds the form at the front is there.
Any tips before I start trying to muscle it around tomorrow? _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu May 26, 2016 11:20 pm Post subject: Re: The Stupid Question Thread |
Thrasher22 wrote: |
Any tips before I start trying to muscle it around tomorrow? |
I have a '69 camper and I use it for ski trips in the winter. The poptop is a bit loose and inhales cold air on the highway. I have a ratchet strap that attaches to the rain gutters and keeps it tight to the roof. The strap goes over the poptop just behind the passenger seat and there is a groove in the poptop that that the strap fits into naturally.
Used with a ratchet this makes a good solution for a rattling poptop. Secure it so it doesn't get lost on the freeway and don't overtighten with the ratchet and pull off the rain gutters.
Aloha
tp |
Posted: Fri May 27, 2016 9:19 am Post subject: Re: The Stupid Question Thread |
Well hopefully that'll be plan B, but I have ratchets, so that might help when I head to the mountains tonight! _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Fri May 27, 2016 11:22 am Post subject: Re: The Stupid Question Thread |
I have used the same thing for the last thirty years on my '70 Westy. Is there any way to keep that top from lifting? _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1538 Location: oregon
Posted: Fri May 27, 2016 12:06 pm Post subject: Re: The Stupid Question Thread |
All you need to keep the top down are the three rubber hold downs, a good set of front hinges and a properly adjusted c clamp bracket thingy that is under the front of the pop top and a decent pop top seal.
I don't use any other, extra hold downs and mine stays tight. I drive in a lot of wind all the time. Just yesterday I drove against solid 35-40mph head winds and cross winds for an hour on the freeway. That probably equates to about 90 mph wind gusts. I was all over the road but the top stayed down just fine. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Tcash Samba Member
Posted: Fri May 27, 2016 12:21 pm Post subject: Re: The Stupid Question Thread |
Westfalia Pop Top |
Posted: Fri May 27, 2016 10:20 pm Post subject: Re: The Stupid Question Thread |
Moved the pop top slightly forward and redid the front seal where it meets the luggage rack and it got rid of 50% of the gap. Still sits high on the driver's side, might take a heat gun to the seal and see if I can finesse it a bit more _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Sawspa Samba Member
Joined: May 12, 2012 Posts: 173 Location: South-East Ohio
Posted: Sat May 28, 2016 4:21 am Post subject: Re: The Stupid Question Thread |
Is there a need to have the vacuum line that runs to the brake servo, be a rigid line. The ends of my hard plastic lines have broken down and causing vacuum leaks. I want to replace the plastic portions of this line with rubber hose. Is it going to collapse? My problem im having is when I apply the brakes, my motor faulters and stalls. 2.0FI 1978 _________________ 1978 Westfalia Campmobile 2.0L oversized ham heads and a stepped up cam, running points and a 76 exhaust "Lefty Loosy" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 28, 2016 9:13 am Post subject: Re: The Stupid Question Thread |
Regular rubber hose won't work as it will indeed collapse, there is reinforced hose available for vacuum use, your FLAPS should have it.
But if your idle changes when you apply the brakes the hose is working fine, the booster is the problem. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Sawspa Samba Member
Posted: Sat May 28, 2016 9:20 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
But if your idle changes when you apply the brakes the hose is working fine, the booster is the problem. |
I used fuel vapor pvc/eec 3/8ths line. It says"not for fuel injection on it. Its all i had. But, it has solved my problems. What size hose should i get? The local FLAPS just have standard sizes usually. _________________ 1978 Westfalia Campmobile 2.0L oversized ham heads and a stepped up cam, running points and a 76 exhaust "Lefty Loosy" |
Posted: Sat May 28, 2016 10:16 am Post subject: Re: The Stupid Question Thread |
Sawspa wrote: |
busdaddy wrote: |
I used fuel vapor pvc/eec 3/8ths line. It says"not for fuel injection on it. Its all i had. But, it has solved my problems. What size hose should i get? The local FLAPS just have standard sizes usually. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=465843&highlight=booster+hose _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Tue May 31, 2016 5:36 am Post subject: Re: The Stupid Question Thread |
Anybody have any ideas where I can find 3 piston pins?
During my disassembly I seem to have lost 3. Now I'm needing to ship off the internals to get balanced but I don't have all 8 piston pins.
The classifieds have not rendered any goodies this morning, and I'm already behind schedule. if anyone has any piston pins for 94mm pistons in a 2.0L please contact me! _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Manfred58sc Samba Member
Posted: Tue May 31, 2016 6:33 am Post subject: Re: The Stupid Question Thread |
I have a set, let me inspect them closely for wear..pm later in the day _________________ Fat chick owner/operator |
Posted: Tue May 31, 2016 6:46 am Post subject: Re: The Stupid Question Thread |
Manfred58sc wrote: |
I have a set, let me inspect them closely for wear..pm later in the day |
Thanks!! I'll PM you this afternoon/evening. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Tue May 31, 2016 7:42 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Back off both parking brake cables so they are drooping, then adjust the star wheels equal clicks from bottomed out until they won't turn anymore (long past where the wheel stops turning), then back them off until the wheel just turns with a tiny drag. after that's all done set the brake cables so it starts to drag at 3 clicks of the handle. |
Thank you mucho. All fixed |
72lowslow Samba Member
Joined: September 22, 2015 Posts: 138 Location: Delaware
Posted: Tue May 31, 2016 7:54 pm Post subject: Re: The Stupid Question Thread |
He
This question's maybe broken all a about stupidity!
1- What I'm supposed to do with this hole?
Because is splashing oil, on my battery, and all over the place.
cover it, is bad idea, I already find that!
2- After cruising for about 20-30 minutes to 40-50 mph I check the temperature oil with a dip fried thermometer and was between 190ºF - 200ºF !
The this temperatures are okay and safe for the engine?
Thanks
Balt _________________ If you want to get into this hobby better you have a very strong strong wallet. |
