Steering column
schwartzkafer
schwartzkafer is offline
PostPosted: Wed May 18, 2016 1:39 pm    Post subject: Steering column Reply with quote
Does anyone know if the steering shaft from a 1956 T1 is the same length/diameter as the 1960s T1? I know the splines are not going to be the same, but I am using an aftermarket steering wheel, so that doesn't bother me. Just need to know if I can swap one for the other.
EVfun
EVfun is offline
PostPosted: Wed May 18, 2016 4:08 pm    Post subject: Re: Steering column Reply with quote
Starting with 1960 the steering column got a little shorter to accommodate the new dished steering wheel. The turn signal switch was completely different starting that year too.
Wildthings wrote:
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Wed May 18, 2016 4:51 pm    Post subject: Re: Steering column Reply with quote
1960 and later shafts ARE shorter in length, same diameter and all 1956 and later splines are the smooth type, same.... you can use a later column with the later style directional indicator switch, as mentioned
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
