1983 GTI Callaway Turbo 2.0l 8v
Forum Index -> Water-cooled VW Share: Facebook Twitter
origsix38
origsix38 is offline
PostPosted: Fri Mar 25, 2016 12:09 pm    Post subject: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
Having an issue with post Boost stall.Boost set @ 6PSI. Does anyone have an idea what recirculating or diverting valve can be used with this engine.
ps2375
ps2375 is offline
PostPosted: Sat Mar 26, 2016 6:46 pm    Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
If you are still on CIS, wouldn't it be easier to add a dashpot to the throttle stop or to raise the idle speed a bit? Your management has no ability to control a recirc or divert valve. What about a blow-off valve?
origsix38
PostPosted: Sun Mar 27, 2016 12:02 pm    Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
HI Happy Easter I have a Blow-off valve that is presently adjusted to max Blowoff. I'm thinking if I re-adjust the setting to minimal blowoff the back pressure to the Turbo will prevent the Post Boost stall. The idle speed is presently 1000rpm. Engine is a 2.0l 8v with Callaway Turbo
ps2375
ps2375 is offline
PostPosted: Sun Mar 27, 2016 12:57 pm    Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
What are you using to deliver the fuel?
origsix38
PostPosted: Sun Mar 27, 2016 2:58 pm    Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
Hi Can you be more descriptive, Injectors are Chrysler 45lb injectors
ps2375
ps2375 is offline
PostPosted: Sun Mar 27, 2016 4:35 pm    Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v Reply with quote
CIS, Digi, standalone like MS....sounds like a tuning issue.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
