mawman2025 Samba Member
Posted: Sun Feb 21, 2016 2:22 pm Post subject: MK1 Golf (Rabbit) Project! |
I bought a MK1 Rabbit under the impression everything was there and it just need put back together. As many of you probably know that is far from the case here. The engine is where all the issues are. It is an ABA 2.0 block with a 1.8 8 valve head with an OBX cam and cam gear and an OBX header. The person that built this motor cannot be tracked down and it is still running the CIS mechanical fuel injection. My question is regarding the Warm Up Regulator and if I need that or if it is possible to substitute something in its place that might be easier to work with or if I could just delete that part all together. Any and all replies are much appreciated. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Feb 21, 2016 3:50 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
I'm pretty sure you need it, and you could only substitute it with one from a Volvo turbo car if, you were to go FI. That part is one of the main reasons I went EFI on my Rabbit years ago. (MegaSquirt) I got tired of the hard starts and buying a rebuilt one was costly then, not even sure you can find them now. You might check some of the local yards for one.
Put an ABA head on it and I'll sell you my ported mkIV intake manifold. |
Posted: Sun Feb 21, 2016 4:51 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
ps2375 wrote: |
I bought one but I'm having to CNC machine an adapter plate for it and I'm getting tired of messing with it. If I was going to swap heads I would go with a 1.8 16 valve head and do an ABF replica and possibly turbo it but that's just my imagination talking. I wouldn't be able to afford that. |
ps2375 Samba Member
Posted: Sun Feb 21, 2016 4:58 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
That piece should be available on any CIS motor at a yard. But, since you have an ABA block, not the same thing. |
Posted: Sun Feb 21, 2016 5:03 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
ps2375 wrote: |
I'm getting a custom CNC adapter plate made so I can mount the WUR. |
ps2375 Samba Member
Posted: Sun Feb 21, 2016 7:49 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
If it were me, I'd lose the CIS and go efi, cause in the long run,it'll be easier to tune, and keep running. There are no parts for the fuel distributors, other than another fuel dist. And depending upon how, where and for how long the system has been down/apart, things get gummed up and seals deteriorate. Then you need to find another working one... |
Posted: Mon Feb 22, 2016 1:36 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
I've considered going with a standalone but I don't know what injectors would fit in the head I have or where to find that information so at the moment it would be easier for me to get the WUR mounted and hope it fires up. |
ps2375 Samba Member
Posted: Mon Feb 22, 2016 1:49 pm Post subject: Re: MK1 Golf (Rabbit) Project! |
For the counter-flow head, digi injectors and fuel rail, if you back to the ABA (cross-flow) head, The injectors and rail for the intake mani you use.
I do know that there might be an issue for the cups and fuel rail mounts depending upon the year of manufacture of the counter-flow head, as the early ones didn't have the boss drilled and tapped for the mounts and I think there might be two diff thread pitches/sizes for the cups.
Other than that, it would be pretty easy to setup. Easier with the ABA head, as the manifold I have also includes injectors, fuel rail, valve cover and oil fill/breather cap. |
