'57 Pedal Assembly Refurbish
boxkiteflyer
boxkiteflyer is offline
PostPosted: Sat Jan 19, 2013 7:41 am    Post subject: '57 Pedal Assembly Refurbish Reply with quote
Pedals cleaned and repainted. The right side of LHD clutch shaft tube is stepped to receive a bushing. Is there supposed to be a bushing on the pedal side? The tube I.D. measures ~19mm and there is no shoulder or step for a bushing on pedal side. The clutch shaft measures ~17mm O.D. so there is significant 'slop' on this side. Thanks!
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Jan 19, 2013 12:58 pm    Post subject: Reply with quote
According to the parts manual there should be:
1. Qty 2 of the 111 721 113 A listed as for the brake, but looks like one of these also does the clutch on the left.
2. Qty 1 of the 111 721 137 for the clutch on the right
In Stereo, Where Available!
boxkiteflyer
PostPosted: Sun Jan 20, 2013 8:15 am    Post subject: Reply with quote
Thanks! Where can these be purchased? WW doesn't have them listed.
Eric&Barb
PostPosted: Sun Jan 20, 2013 8:37 am    Post subject: Reply with quote
Might try the rebuilder of pedal assemblies in the classifieds, or have a local machine shop make a dozen or more, and sell the extras to cover your cost.
boxkiteflyer
PostPosted: Sun Jan 20, 2013 7:46 pm    Post subject: Reply with quote
Yeah- I think I'll have machinist friend make one long one for the clutch shaft and tube out of high density molecular weight nylon or whatever that stuff is called. I would think an interference fit for the tube to keep the bushing in place would be ideal. Plus, it'll never need grease! I did this for my '58 MGA's steering column at the ends in lieu of using oiled felts as per the original!
PedalWerks
PedalWerks is offline
PostPosted: Sat Feb 09, 2013 4:27 pm    Post subject: Pedal Bushings Reply with quote
I have been making these bushings and rebuilding Oval Pedal assemblies since 2005, in 98 out of 100 Pre Aug 57 pedals this bushing is missing from that side,
Please let me know how they turn out,
Scott
Nothing Exceeds Like Excess!!!
www.pedalwerks.com
@pedalwerksdotcom
909-289-9655
12' Golf 2.5
07' Rabbit 2.5
59' Single Cab
57' Oval hard top
55' Oval hardtop
