boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Mon Jan 14, 2013 6:50 am Post subject: Boost Gauge Pipe Route to Supercharger |
How do you folks with Judsons et al route your boost gauge pipe? I am going to replace my fuel pipe and thought I might as well route two pipes: one for fuel and other for the SC. Any thoughts or considerations on this? Thanks! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13953 Location: Southampton U.K.
Posted: Mon Jan 14, 2013 10:05 pm Post subject: |
John- nice pics and thanks! I suppose the pipe comes out of carpet at footwell and runs, exposed, vertically to gauge? My gauge has a flush mount portion so it can be attached to any convenient flat area (like under dash). Your car looks as if it is right hand drive for pipe is on right side of tunnel, correct? |
D-train Samba Member
Posted: Wed Jan 16, 2013 1:52 am Post subject: |
i ran my gauge line up the roof line instead of chassis, along side the wiring loom in the oval, no drilling then.. _________________ shiny paint doesnt make it worth any more |
Posted: Wed Jan 16, 2013 1:28 pm Post subject: |
D-train, how did you get the pipe into the passenger compartment?
I'd post a picture of my gauge but, for the life of me, can't figure it out on this site! I've read the instructions but they don't make sense. Other than typing the brackets with 'img' there has got to be an easier way. I post pics all the time on other forums. |
Posted: Wed Jan 16, 2013 3:50 pm Post subject: |
boxkiteflyer wrote: |
Up through the roof line next to the wiring harness
Out next to the heater demister pipe
Then in through an existing hole
Then to the gauge, sorry about the blurry pic.
Something's there is sound proof stuff in the roofline so might have to run a wire to pull it through.
I use photobucket cause I'm the same an cant figure out the upload pic thing..
I'm a bit special. Haha _________________ shiny paint doesnt make it worth any more |
Posted: Wed Jan 16, 2013 5:12 pm Post subject: |
Even Everett has tried to help me post pics but I'm too stupid or sump'n! D-train and John- do you use steel pipe or rubber hose pipe? I'm currently putting new wiring harness, fuel pipe and everything in my car so I have quite a few options for routing the boost gauge pipe thanks to your input. Thanks for complicating things Just kidding, dontchaknow! |
Posted: Wed Jan 16, 2013 5:49 pm Post subject: |
Both runnin rubber hose for it, I'd like to swap to steel line, just cause rubber perishes after a while but it works for now so why change it.
While ur doin everything else run it too saves u havin to do it all later when it's more fiddly.. _________________ shiny paint doesnt make it worth any more |
kiwi_obecny Samba Member
Joined: October 23, 2010 Posts: 20 Location: Czech Republic
Suboval Samba Member
Posted: Thu Jan 17, 2013 10:00 am Post subject: |
I agree with D-train - thru the roof (similar to how the wiring is run on the passenger side).
I had an Oval with a Motominder gauge originally installed and the teflon tubing was run the same as D-trains tubing, except on the driver's side. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Thu Jan 17, 2013 11:24 am Post subject: |
Thanks for the comments. I'm leaning toward a thru-the-tunnel route whereupon the fuel and boost pipes can be 'married' together but the driver's side roof route is interesting, too!
kiwi obecny- the flat4 forum posts are awesome! The pics were so good I didn't even need to translate! I like the thru-the-bulkhead pipe connectors and how you made those brass ferrules for the ends of your pipes. |
