theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Tue Oct 26, 2010 10:43 am Post subject: |
Crankey wrote: |
My "last step" was flitz. But L'll have another go with the dykem.
Thanks. |
Let us know how they turn out, and post pics when you get done!
RareAir wrote: |
theastronaut wrote: |
Crankshaft rod throws and counterweight edges. Steel, not aluminum but it's the same process:
That looks awesome |
Thanks! Now if I could find the time to finish it...
I've got a thread detailing the process over in the engine/performance section.
http://www.thesamba.com/vw/forum/viewtopic.php?t=418307&highlight=knife+edge _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Wed Oct 27, 2010 9:33 pm Post subject: |
If you want to save a lot of time and money, go down to Harbor Freight if you have one near by and get yourself a 6" or 8" buffer and a stand. For most things you can use 320 grit sand paper and the buffer will do the rest. Other things you may have to use 220 then 320 but I've never had to go any higher than 320. I've been doing polishing for quite a while now and I pretty much do it for a living so if you need any help let me know!
Before...
After....
deaner Samba Member
Posted: Fri Oct 29, 2010 10:16 pm Post subject: |
we use the neverdull stuff on many things at my aviation restoration shop.
props, kick plates, engine parts...must be using a different method.
_________________ 65 bug
68 bug
70 ghia |
Posted: Fri Oct 29, 2010 10:41 pm Post subject: |
deaner wrote: |
That stuff works ok but it's a bit abrasive. I used it on something I polished on my buffer and it scratched the crap out of it so I ended up re-polishing it on my buffer. lol |
hazegry Samba Member
Joined: April 04, 2003 Posts: 42 Location: Norfolk Va
Posted: Fri Feb 04, 2011 7:58 pm Post subject: |
Jays58 what kind of polishing compounds and wheels are you using? _________________ www.scribblingpens.com |
Posted: Fri Feb 04, 2011 8:00 pm Post subject: |
hazegry wrote: |
Jays58 what kind of polishing compounds and wheels are you using? |
I use the green only. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Fri Feb 04, 2011 10:21 pm Post subject: |
I use this stuff. I goes on easy and works like MAGIC!!!!
do a google search _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Fri Feb 04, 2011 10:24 pm Post subject: |
hazegry wrote: |
The buffing wheels I just use the soft pad for softer aluminum parts and the stiff stitched pads for the harder aluminum parts and I get them from my local ace hardware store. |
Posted: Sat Feb 05, 2011 7:01 pm Post subject: |
ok went and got a soft pad and started polishing I am getting pitts showing up it almost looks like pours in your skin it takes a good bit to polishing to get them out. My buffer only hits 1750 rpms though. _________________ www.scribblingpens.com |
Crankey Samba Member
Posted: Sat Feb 05, 2011 8:13 pm Post subject: |
that's a good rpm for a buffer. if you want to get pits out you'll need to sand them before buffing. |
Posted: Sun Feb 06, 2011 8:03 am Post subject: |
thats the weird thing I did sand the parts its ones I polished by hand and hit with the buffer to make them look better. I am going to get another wheel today and a more aggressive cut compound and try doing a 2 step process. _________________ www.scribblingpens.com |
Posted: Sun Feb 06, 2011 11:48 am Post subject: |
hmm, any possibility it's porosity in a casting or maybe porosity in a weld that's been ground flush ? |
Posted: Sun Feb 06, 2011 12:40 pm Post subject: |
probably crappy aluminum its just parts for my RC raceboat think I got it knocked out now. Thanks guys _________________ www.scribblingpens.com |
Weezo182 Samba Member
Posted: Sun Feb 27, 2011 7:57 pm Post subject: |
mothers aluminum polish and a dremel works great _________________ www.Weezoonline.com
2004 Honda Element
1956 Buick Special
1974 VW Super Beetle
2004 Honda Ruckus
2003 Honda Ruckus
*Pabst Blue Ribbon* |
eguti66 Samba Member
Joined: July 21, 2004 Posts: 260 Location: Stockton,CA
Posted: Sun May 15, 2011 10:10 pm Post subject: |
jays58s wrote: |
What buffer are using from harbor fright? do u have of a pic of it? _________________
drscope wrote: |
Ummmm, if you can't find out where the hole is by feeling around, then FORGET about installing the light! |
66 beetle
65 karmann ghia
58 beetle
58 convertible beetle
64 11w standard
68 Squareback |
Posted: Sun Oct 02, 2011 9:11 pm Post subject: |
well, not really the level of gleam I was after. but winter came along and I needed to mount tires and run them, these are winter wheels.
now however, I have just ordered some Wenol in the red tube and the finer polish from Wenol as well. both say they provide a protective film too, I hope they do.
I have started a new set of wheels, but these are real 3 piece BBS so I need to get them really nice.
I got them buffed with black then brown and then green compound. after the black, they looked pritty great, the brown and green seemed to put a dull haze on it though. I hope the Wenol will do what I want. seems like maybe it would be good to go with that after the black buffing compound ?
in this pic the spokes are polished with black compound, the center caps are just sanded to 600.
since then I have sanded the center cap plates to 1000 grit and polished them, just with the black polish. the seem to have a different gleam, maybe the alloy ? anyway the caps seem brighter to me. the lips in the pics are factory polish from Tunershop. all I've done is sand off the clear coat and polish the spokes and center caps. I'm keeping the paint detail in the windows.
I'm really looking forward to getting the Wenol and seeing what it can do. can it be used on a buffing wheel mounted in a drill or is it made for hand use on a rag ?
after all this work, is there a clear coat that's any good ? I'm inclined to use a wax or hopefully, the Wenol can provide some protection. it rains alot here.
kind of a crappy pic, but here the center cap is polished and there is a center disc that I am making to replace the typical BBS nut. the idea is to get a lower profile.
oh, and I've found a sharpie pen works well as 'dykem'. it's easy to blacken spots that need more sanding. most of it goes away fast but it leaves a ghost of the sharpie lines till it's fully sanded clean. it needs to be dry before you sand but it drys fast. I used it with 1000 grit and don't feel it clogged my wet sanding. |
Posted: Sat Oct 15, 2011 1:30 pm Post subject: |
got the Wenol...not very pleased with it. I had buffed my wheel centers with the black rouge on a small buffing wheel, they looked pretty great really. I thought the Wenol should get them a bit brighter and take out the fine buffing lines, but it just dulled the shine. the small area I tried it on looks like a mirror with some semi gloss clear coat on it. dull and hazy. |
avoll Samba Member
Joined: September 04, 2014 Posts: 119 Location: Ottumwa
Posted: Sat Oct 14, 2017 11:05 am Post subject: Re: Polishing Aluminum to Show Quality.. How? |
Just wanted to share with everyone.
I had to polish my chrome on my bay bus, and it was oxidized/dis colored milky white.
I tried several things, but nothing really worked except - White Diamond Metal Polish.
Worked amazing compared to everything else. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6622 Location: Houston, Texas
Posted: Sun Oct 22, 2017 8:57 pm Post subject: Re: Polishing Aluminum to Show Quality.. How? |
_________________ www.vwnos.com [email protected]
sblu Samba Member
Joined: April 08, 2019 Posts: 95 Location: Austin, TX
Posted: Mon May 16, 2022 5:24 pm Post subject: Re: Polishing Aluminum to Show Quality.. How? |
reawakening an older thread; its 2022 and i'm trying to polish the ALUMINUM trim around the front window. not getting the shine i need. whats the latest black-magic to do this? first time doing it; I did all teh layers of sandpaper I had from 250 to 2000 and then a 000 steel wool with the polish shown; then also dusted off my dremel w/ the little red block of wax. not nearly close!!! Tools of the trade I have on-hand and tried...
_________________ 1978 Westfalia Champagne Edition Project |
