Parts/Accessories - Ghia
Moderators: None
Page: 1, 2, 3 ... 67, 68, 69  Next
Upload Pic
Title only
Category :: Parts/Accessories - Ghia
anodized side panel in engine compartment
Posted: Mon Jun 27, 2016 5:03 am
Rating: Not rated
crocteau
worked up some aluminum side panels for engine compartment, had them hard anodized black, and used Camloc quarter-turn fasteners to hold in place
View other images:
From crocteau Rows Grid
engine in place in Ghia
Posted: Fri Jun 24, 2016 4:03 pm
Rating: Not rated
crocteau
from the stand to slipping onto the lower studs took less than ten minutes; had to remove the dipstick to clear the rear apron, and from there on it was smooth sailing
View other images:
ready to re-install engine in Ghia
Posted: Fri Jun 24, 2016 3:55 pm
Rating: Not rated
crocteau
had to strip car from the doors back for rear-end collision repair
View other images:
bumper bracket cover
Posted: Fri Jun 24, 2016 3:42 pm
Rating: Not rated
crocteau
right rear bumper bracket and cover installed before mounting outer bumper blade
View other images:
Ghia 71 Tab
Posted: Thu Jun 23, 2016 9:32 pm
Rating: Not rated
Ghia 71 Tab
Bloku
tab
View other images:
From Bloku Rows Grid
Oklahoma
Posted: Thu Jun 23, 2016 9:30 pm
Rating: Not rated
Oklahoma
Bloku
Black Plate "Decals"
View other images:
Oklahoma
Rating: Not rated
Oklahoma
Bloku
View other images:
Oklahoma
Rating: Not rated
Oklahoma
Bloku
View other images:
WCM tar board
Posted: Tue Jun 21, 2016 6:25 am
Rating: Not rated
WCM tar board
PeteSC
West Coast Metric tar board kit. It's a very nice product.
View other images:
From PeteSC Rows Grid
Harrington stainless front bumper
Posted: Tue Jun 21, 2016 6:10 am
Rating: Not rated
PeteSC
Finally got it to fit after modifying by loosening bolts that hold blade sections to center piece, then removing the guards and their retaining bolts. Pushed blade ends outward until it measured 59.25" from inside of blade end to end. Tightened center section bolts carefully while not letting blades draw back in (maintain 59.25" spread). Re-drilled bolt holes for guards since they now were off due to pushing the blades outward, then reinstall guards.
Blade end-to-body nut plates are at the wrong angle, so I drilled out the nut and inserted a rivet nut at the correct angle, secured w/ JB weld. Seems to be holding - these are more for stability of the blade ends rather than holding significant weight it seems. Time will tell.
View other images:
Rating: Not rated
PeteSC
View other images:
Rating: Not rated
PeteSC
View other images:
Weber IDF40 Throttle
Posted: Mon Jun 20, 2016 7:43 pm
Rating: Not rated
RHough
photos of idle, transition and vacuum advance ports
View other images:
From RHough Rows Grid
Rating: Not rated
RHough
View other images:
Rating: Not rated
RHough
View other images:
Harrington stainless euro bumper
Posted: Fri Jun 10, 2016 5:25 am
Rating: Not rated
PeteSC
Well they can make a rear bumper that bolts right up....why is the front so difficult?
View other images:
Harrington bumpers from CIP1
Posted: Thu Jun 09, 2016 5:32 am
Rating: Not rated
PeteSC
View other images:
Posted: Thu Jun 09, 2016 5:15 am
Rating: Not rated
PeteSC
They look nice when assembled, but the front bumper is 2.25" shorter than an original bumper
View other images:
Rating: Not rated
PeteSC
View other images:
kraftfahrzeugbrief
Posted: Mon Jun 06, 2016 2:44 pm
Rating: Not rated
kraftfahrzeugbrief
Joostt
View other images:
From Joostt Rows Grid
IDF w/32 mm Venturi
Posted: Wed Jun 01, 2016 9:17 pm
Rating: Not rated
IDF w/32 mm Venturi
RHough
The intake eye view of IDF40's with short velocity stacks
View other images:
IDF w/32 mm Venturi
Rating: Not rated
IDF w/32 mm Venturi
RHough
View other images:
IDF w/32 mm Venturi
Rating: Not rated
IDF w/32 mm Venturi
RHough
View other images:
IDF w/32 mm Venturi
Rating: Not rated
IDF w/32 mm Venturi
RHough
View other images:
IDF w/32 mm Venturi
Rating: Not rated
IDF w/32 mm Venturi
RHough
View other images:
IDF w/32 mm Venturi
Rating: Not rated
IDF w/32 mm Venturi
RHough
View other images:
Heatpump
Posted: Sun May 29, 2016 6:46 am
Rating: Not rated
Heatpump
SoCalJes
Heat pump ac with reversing valve
View other images:
From SoCalJes Rows Grid
Heatpump
Rating: Not rated
Heatpump
SoCalJes
View other images:
Posted: Sun May 22, 2016 10:57 am
Rating: Not rated
1915
bugguy1967
1915, CB 2234, 034 heads, stock balanced bottom end, stock fly and equalizer pulley, AA 94s, CB/Manton Aluminum pushrods, 8.5:1 comp, 1 3/8" header, 40 HPMXs
View other images:
From bugguy1967 Rows Grid
NOS karmann ghia battery tray
Posted: Sat May 21, 2016 7:54 am
Rating: Not rated
Jake Martinez
View other images:
From Jake Martinez Rows Grid
Rating: Not rated
Jake Martinez
View other images:
Rating: Not rated
Jake Martinez
View other images:
Lowlight Bumpers, Headlights, Turn Signals
Posted: Sun May 15, 2016 8:57 pm
Rating: Not rated
vegasSTEVE
Test fitting
View other images:
From vegasSTEVE Rows Grid
Rating: Not rated
vegasSTEVE
Test fitting
View other images:
Rating: Not rated
vegasSTEVE
Test fitting
View other images:
Rating: Not rated
vegasSTEVE
Test fitting
View other images:
Rating: Not rated
vegasSTEVE
Test fitting
View other images:
for the forums
Posted: Sun May 15, 2016 6:32 pm
Rating: Not rated
for the forums
kingkarmann
stuck in my engine duh!!!
View other images:
From kingkarmann Rows Grid
for the forums
Rating: Not rated
for the forums
kingkarmann
View other images:
european turn signal switch
Posted: Mon May 09, 2016 5:11 pm
Rating: Not rated
djway3474
View other images:
From djway3474 Rows Grid
Tachometer
Posted: Mon May 09, 2016 7:02 am
Rating: Not rated
Tachometer
vegasSTEVE
Tachometer from Ghia clock + Speedo Glass + 914-4 tachometer + patience
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Posted: Mon May 09, 2016 7:01 am
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Tachometer
Rating: Not rated
Tachometer
vegasSTEVE
View other images:
Karmann Ghia engine compartment side panel
Posted: Sun May 08, 2016 12:07 pm
Rating: Not rated
crocteau
work in progress
View other images:
Select sort method:  Order:
Gallery Index -> Parts/Accessories - Ghia
Page 1 of 69
You cannot upload new pics in this category
You cannot rate pics in this category
You cannot edit your pics and comments in this category
You cannot delete your pics and comments in this category
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
