Thing/Type 181
Moderators: None
Page: 1, 2, 3 ... 406, 407, 408  Next
Upload Pic
Title only
Category :: Thing/Type 181
cleaning the carbs. while waiting for parts
Posted: Yesterday 4:22 pm
Rating: Not rated
vw moses
adding flat washers to carb. top screws
View other images:
From vw moses Rows Grid
Rating: Not rated
vw moses
the lock washers dug into carb top
View other images:
Rating: Not rated
vw moses
another view of damage
View other images:
Rating: Not rated
vw moses
culprit lock washer--needed
, but need to protect carb.
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
heres how they'll go back
View other images:
The Headlight Problem!
Posted: Yesterday 1:05 am
Rating: Not rated
jackman
View other images:
From jackman Rows Grid
Rating: Not rated
jackman
View other images:
wheel bearing
Posted: Sun Jul 17, 2016 4:26 pm
Rating: Not rated
wheel bearing
KAmes
View other images:
From KAmes Rows Grid
thing wheels
Posted: Sun Jul 17, 2016 9:23 am
Rating: Not rated
thing wheels
117harv
View other images:
From 117harv Rows Grid
thingwiring
Posted: Sat Jul 16, 2016 11:08 pm
Rating: Not rated
thingwiring
Bucky85
View other images:
From Bucky85 Rows Grid
rear wheel bearing
Posted: Sat Jul 16, 2016 5:11 pm
Rating: Not rated
rear wheel bearing
KAmes
View other images:
rear wheel bearings
Posted: Sat Jul 16, 2016 4:49 pm
Rating: Not rated
rear wheel bearings
KAmes
View other images:
rear wheel bearings
Rating: Not rated
rear wheel bearings
KAmes
View other images:
rear wheel bearings
Rating: Not rated
rear wheel bearings
KAmes
View other images:
rear wheel bearings
Rating: Not rated
rear wheel bearings
KAmes
View other images:
rear wheel bearings
Rating: Not rated
rear wheel bearings
KAmes
View other images:
rear wheel bearings
Rating: Not rated
rear wheel bearings
KAmes
View other images:
installing that shim i needed
Posted: Fri Jul 15, 2016 3:27 pm
Rating: Not rated
vw moses
worked perfect to stop the exesive noisy play
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
View other images:
cleaning the surface where gasket will go
Posted: Fri Jul 15, 2016 3:24 pm
Rating: Not rated
vw moses
adapter for remote oil cooler
View other images:
Rating: Not rated
vw moses
View other images:
attaching new carb. "push pull"
Posted: Fri Jul 15, 2016 3:08 pm
Rating: Not rated
vw moses
removing stock stud
double nut method
View other images:
Rating: Not rated
vw moses
supplied nuts from scat
came out smoothly
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
checking level
with square off the blok
View other images:
Rating: Not rated
vw moses
close, but i'll notch it, anyway
View other images:
Rating: Not rated
vw moses
just grinded a bit w/grinder
View other images:
Rating: Not rated
vw moses
i've got expansion clearence!
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
View other images:
cleaning the manifolds
Posted: Fri Jul 15, 2016 2:49 pm
Rating: Not rated
vw moses
sanding off gasket residue
creating good flat surface
View other images:
Rating: Not rated
vw moses
before shot
View other images:
Rating: Not rated
vw moses
View other images:
Posted: Fri Jul 15, 2016 2:48 pm
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
View other images:
Rating: Not rated
vw moses
down the hatch!
View other images:
Rating: Not rated
vw moses
top view of the isolators
there port matched
View other images:
181 in the movies
Posted: Thu Jul 14, 2016 9:07 pm
Rating: Not rated
181 in the movies
Semper_Dad
181 substituting for kubelwagon in movie "Out of the Ashes" (2003)
View other images:
From Semper_Dad Rows Grid
Every which way but loose
Posted: Thu Jul 14, 2016 4:21 pm
Rating: Not rated
Shoyrtt
View other images:
From Shoyrtt Rows Grid
Sales literature 181
Posted: Wed Jul 13, 2016 9:37 pm
Rating: Not rated
Metal Twister
View other images:
From Metal Twister Rows Grid
74 Thing Speedo
Posted: Wed Jul 13, 2016 12:30 pm
Rating: Not rated
74 Thing Speedo
1madmanx
View other images:
From 1madmanx Rows Grid
engine
Posted: Mon Jul 11, 2016 11:27 am
Rating: Not rated
engine
KAmes
View other images:
engine repair
Posted: Sat Jul 09, 2016 7:56 pm
Rating: Not rated
engine repair
KAmes
View other images:
engine repair
Rating: Not rated
engine repair
KAmes
View other images:
painting some tin-ware while waiting for parts
Posted: Sat Jul 09, 2016 4:08 pm
Rating: Not rated
vw moses
cool tins and breast plate
i ran out of paint while doing the cool tins
that'll be my primer coat until i get another can
View other images:
Rating: Not rated
vw moses
coil bracket
red is warning color for "IT WILL SHOCK YOU"
View other images:
Select sort method:  Order:
Gallery Index -> Thing/Type 181
Page 1 of 408
You cannot upload new pics in this category
You cannot rate pics in this category
You cannot edit your pics and comments in this category
You cannot delete your pics and comments in this category
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
