Bug - Super Beetle
Moderators: None
Page: 1, 2, 3 ... 702, 703, 704  Next
Upload Pic
Title only
Category :: Bug - Super Beetle
Drive your VW to work day
Posted: Today 5:42 am
Rating: Not rated
Lingwendil
D
View other images:
From Lingwendil Rows Grid
Rating: Not rated
Lingwendil
D
View other images:
3D printed 71-mid 73 strut mount grease caps
Posted: Yesterday 1:46 pm
Rating: Not rated
Scorpwanna
Found a website that allows me to upload 3D models of parts to have printed. This is a grease cap I made for myself.
View other images:
From Scorpwanna Rows Grid
78 SB FI wiring
Posted: Thu Jun 23, 2016 7:16 pm
Rating: Not rated
78 SB FI wiring
KKiley
View other images:
From KKiley Rows Grid
Beetle 1303 Front wheel case rust
Posted: Thu Jun 23, 2016 3:30 pm
Rating: Not rated
Patrick_S
View other images:
From Patrick_S Rows Grid
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
Rating: Not rated
Patrick_S
View other images:
My 1973 Super Beetle
Posted: Thu Jun 23, 2016 9:46 am
Rating: Not rated
Beetlebaum
Working on my '73 Bug
View other images:
From Beetlebaum Rows Grid
Rating: Not rated
Beetlebaum
View other images:
Posted: Thu Jun 23, 2016 9:45 am
Rating: Not rated
Beetlebaum
At the Bug Out VW Show.
View other images:
From the BugOut 78 show Rows Grid
Rating: Not rated
Beetlebaum
View other images:
bug wiring
Posted: Thu Jun 23, 2016 9:41 am
Rating: Not rated
bug wiring
justagirlandherbug
View other images:
From justagirlandherbug Rows Grid
bug wiring
Rating: Not rated
bug wiring
justagirlandherbug
View other images:
bug wiring
Rating: Not rated
bug wiring
justagirlandherbug
View other images:
Help I fell in love with a bug
Posted: Thu Jun 23, 2016 1:02 am
Rating: Not rated
justagirlandherbug
Bought a 1971 Super Beetle (vin is 1122016650) this is what the only bit of paperwork says with my bug (no other mechanical receipts)...
-1776 Engine
-90.5 mm cima pistons and cylinders
-camshaft (one step above stock)
-Case, welded #3 true full flow with filter
-HD oil pump
-Oil Sump
-Lightened flywheel
-Ported and Polished heads
-Stock Rockers
-New solid clutch disc
-Stock pressure plate
-Thunderbird header with muffler, stock heater boxes
-Weber Carb 44 IDF 71
-009 Distributor, New Points
I just added this in case you can see anything different in the photos as I've been looking up the 1776 scat engines and it doesn't look like it matches up to what I have (or if you can elaborate on any specs)
My bug isn't turning over and was a hard start when I got it whether warm or cold. Changed fuel filter/oil/cleaned air filter/new fuses... Ran great for a couple days....
Now Fuel isn't getting past fuel filter and fuel pump shakes so violently you can hear it as soon as you turn on the engine. It will sound like it's going to go but won't quite get over the hump and go.
View other images:
Rating: Not rated
justagirlandherbug
-1776 Engine
-HD oil pump
-Oil Sump
-Lightened flywheel
-Stock Rockers
View other images:
Rating: Not rated
justagirlandherbug
-1776 Engine
-HD oil pump
-Oil Sump
-Lightened flywheel
-Stock Rockers
View other images:
Rating: Not rated
justagirlandherbug
-1776 Engine
-HD oil pump
-Oil Sump
-Lightened flywheel
-Stock Rockers
View other images:
Rating: Not rated
justagirlandherbug
-1776 Engine
-HD oil pump
-Oil Sump
-Lightened flywheel
-Stock Rockers
View other images:
Engine pics for examination
Posted: Wed Jun 22, 2016 9:29 pm
Rating: Not rated
mazzrod
View other images:
From mazzrod Rows Grid
Rating: Not rated
mazzrod
View other images:
Rating: Not rated
mazzrod
View other images:
Rating: Not rated
mazzrod
View other images:
Fresh air hose distributor.
Posted: Wed Jun 22, 2016 4:33 pm
Rating: Not rated
Rubber Duck
View other images:
From Rubber Duck Rows Grid
1969 Beetle Wiring mods
Posted: Wed Jun 22, 2016 5:34 am
Rating: Not rated
54bug
Panels and fuse wiring to create new harness and relays for 1969 beetle... Modeled after modern harness/relay systems.
View other images:
From 54bug Rows Grid
Rating: Not rated
54bug
View other images:
Rating: Not rated
54bug
View other images:
In front of my garage...
Posted: Wed Jun 22, 2016 4:42 am
Rating: Not rated
Doktor
...still need to remove that mat black paint on the pop-outs.
View other images:
From Doktor Rows Grid
71 super 1904
Posted: Wed Jun 22, 2016 2:28 am
Rating: Not rated
71 super 1904
icelancer
View other images:
From icelancer Rows Grid
71 super 1904
Rating: Not rated
71 super 1904
icelancer
View other images:
73 Kansas beige 1303
Posted: Tue Jun 21, 2016 9:13 pm
Rating: Not rated
Lingwendil
Stuff
View other images:
Rating: Not rated
Lingwendil
Stuff
View other images:
Posted: Tue Jun 21, 2016 9:12 pm
Rating: Not rated
Lingwendil
Stuff
View other images:
hub cap
Posted: Mon Jun 20, 2016 9:41 am
Rating: Not rated
hub cap
I VANGON
Hey i have 3 and neeeeeed 1.
View other images:
From I VANGON Rows Grid
34 pict 3
Posted: Sun Jun 19, 2016 8:08 pm
Rating: Not rated
34 pict 3
enalnitram
View other images:
From enalnitram Rows Grid
34 pict 3
Posted: Sun Jun 19, 2016 8:05 pm
Rating: Not rated
34 pict 3
enalnitram
View other images:
case
Posted: Sun Jun 19, 2016 11:28 am
Rating: Not rated
case
Vw1600dellortoGR
View other images:
From Vw1600dellortoGR Rows Grid
case repair
Posted: Sun Jun 19, 2016 10:48 am
Rating: Not rated
case repair
Vw1600dellortoGR
View other images:
case repair
Rating: Not rated
case repair
Vw1600dellortoGR
View other images:
case repair
Rating: Not rated
case repair
Vw1600dellortoGR
View other images:
case repair
Rating: Not rated
case repair
Vw1600dellortoGR
View other images:
Select sort method:  Order:
Gallery Index -> Bug - Super Beetle
Page 1 of 704
You cannot upload new pics in this category
You cannot rate pics in this category
You cannot edit your pics and comments in this category
You cannot delete your pics and comments in this category
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
